Reinvent Technology: convert old camcorder tapes to DVD
Hi.
I have these old camcorder tapes which are of no use these days. They cannot be used in the music system even. Can I convert old camcorder tapes to DVD in any way? Thanks in advance!
Hi.
Hi.
You sure can convert old camcorder tapes to DVD by the following given ways-
1) By using a service of conversion. You need to gather the correct equipment and visit the nearest shop/store.
2) The conversion can be done using the 8 mm camcorder. The camcorder can be connected using a firewire cable with the help of which a recorder program can be purchased so as to record the video and then covert it to DVD later on.
3) Another way is not to use the 8 mm camcorder. Instead make use of a VHS player by putting the tape into it.
4) You can buy the essential components and services required for the conversion of old camcorder tapes using 8 mm camcorder.
Hope we helped.
