Relate and download fx rates XML with FXML
XML could be described as to carry data. In relates to Exchange rates Data using XML, could it be possible that XML is similar to FXML?
Can I download FX Rate XML and combined it with FXML which can also handle a currency Rate?
Answered By 0 points N/A #154788
OANDA has access to online currency data and it allows currency authorizations for back office operations and websites. Many organizations worldwide do rely on the OANDA rate data. FXML can be used to access reliable rate data anytime. It decreases data entry resources and errors. Also prevent ongoing hardware and development costs.
 Integration of simple API calls directly into the system is possible to update exchange rates in ERP software. With the Currency Converter it is possible to update views about daily average bid and ask rates for any data.Provision of requests of filtered aggregated data exchange rate anytime is available in XML or CSV format .
 Oanda should be a very good answer for you. You can receive Oanda rates in XML format and integration
is possible with the spreadsheets,web or business systems. No software installation is needed by FXML. Send requests
in the HTTP protocol to OANDA exchange servers which return XML responses.
 FxMail subscription services available including a free one too.
A detailed overview can be derived from
https://www.oanda.com/fx-for-business/
