Release of Ascend D Quad delayed
According to news, Huawei delayed the release of the Ascend D Quad due to "technical problems" they are experiencing with the chipset. When will they be able to fix the problem and finally put it out in the market?
While the official release date is set to July, it is true that Huawei’s Ascend D Quad has encountered some technical problems which caused the delays in production. But the mass production will start in August. So, probably, as of the exact date of the release, there is no reports or confirmation yet as of the moment.
Ascend D Quad is already launched in the market during 2012 August.
It has a mixed review as because first launch date was postponed because of the hardware issue.
If you want to see the reviews and product specification you can go through this link.
Best part is it is equipped with Li-Ion 1800 mAh battery which will give a reasonable stand-by time.
Hope these details will help you.
Ccharle William
Notifications
