Bersh Roman
30 points
Posted on - 06/11/2012
Hi there everyone! I am really enthusiastic about the new snow leopard's release for Mac OS X. But as my internet connection is slow, so i can not download it. Is there any other alternative method of getting the program installed into my system? Thanks.Â
Release of Snow Leopard 10.6.7
Hi Bersh,
You can purchase it from the Apple store and install it from the CD delivered.
The link for the Snow Leopard in Apple store is https://www.apple.com/shop/bag and you have a country list in the bottom of the page so you can change your country.
Basically, the alternative method of having the MAC OS X Snow Leopard to be installed in your computer is to buy it at the apple store. It will cost you US$29 for a single-user license. If you really want to download it however your internet connection is slow, you can contact technical support for your internet service provider for them to check why is your internet connection is slow and make sure that the computer you are using meet the system requirements for MAC OS X Snow Leopard.
Check the link for the system requirements: https://en.wikipedia.org/wiki/Mac_OS_X_Snow_Leopard
Hi Bersh Roman,
Rather than Downloading the snow leopard's release for Mac OS X from internet you can get the same from Apple Website or its retail Store. It costs US$29 and it is for a single-user license.
