Relevance Of Map MY Ride and Bike Hub Cycle Journey Planner
What are the significant features of the Map My Ride Application? What measure can I put in place to ensure an optimum use of this application? What does the Bike Hub Cycle Journey Planner application share in common with the Map My Ride Application? What are the distinct features between these two apps? Which of the apps will you recommend as a first choice if you are to only select one of them?
Answered By 0 points N/A #188576
Map My Ride:
Map My Ride is a fitness tracking application that enables you to use the built-in GPS of your mobile device to track all of your fitness activities. Record your work out details, including duration, distance, pace, speed, elevation, calories burned, and route traveled on an interactive map. You can even effortlessly save and upload your workout data to Map My Ride where you can view your route workout data, and comprehensive workout history.
Bike Hub Cycle Journey Planner:
The Bike Hub app finds the quickest or quietest cycle routes; and can locate your nearest bike shops. This is NOT a sports app. It won’t link to your HRM with ANT+; tell you how many donuts you’ve burnt; or Twitter your cycle ride stats.
