I worked for quite a while to download all of the components to run this app and when I finally got it to come up
I could not get it to do anything says it is a read only? I saved the database to my laptop as instructed still no go.
Any idea what the problem is?
All I want is a place that I can record my reloading supplies brass lead etc.
Reloaders Reference v 9.3x74R
‘C: test1Idata.mdb’ is not a valid path. Make sure that the path name is spelled correctly and that you are connected to the server on which the file resides.
Reloaders Reference v 9 3x74R encountered an error
It seems like the path of the database file is invalid. If the instruction was to download the database to your hard drive, make sure you save it in the correct folder. I think the program is expecting the database file in “C:Test1Idata.mdb” but unfortunately the “Idata.mdb” database file you downloaded is located on a different folder.
If this is the case, you simply need to transfer the downloaded database file to “C:Test1” to fix the problem. Once the database file is already there, the application will be able to find it and load it successfully. Since you are not using the latest version, download Reloaders’ Reference RRv93x74r. It works on Microsoft Windows, Mac OS X, and Linux.
The objective of the application was to create a sole reference that will have all the publicly available data from documented sources for metallic cartridge reloading.
