Remote Access Connection Failure With Computer
As I was fiddling with my system unit an error suddenly appeared. I took the liberty of copy pasting the error here in a form of a JPG.
This happened as I was trying to remotely access one of the workstations in the company. I hope someone out there can help me with this problem I have currently at hand. Thanks in advance.
There was no endpoint listening at Net.pipe://mh59504/Connect/Service/IndexingService/that could accept the message.
Details
Connection failure with computer (MH59504)
accept the message. This is often caused by an incorrect address or
SOAP action. See innerException, if present, for more details.
The pipe endpoint
‘net.pipe://mh58504/connectService/IndexingService/’ Could not be
found on your local machine.
Best Answer by Knight Frakes
Answered By 5 points N/A #170631
Greetings,
The error you are getting could possibly mean that the request is not sent to the right URI or the service is not started. Verify that the URI is used by the client/server. You may want to check the event logs for errors.
Another good thing to check is the listening service. Open the run window and type services.msc. Look for "Net.Pipe Listener Adapter" then double click it. Check if it is started. If not, start the service.
Answered By 0 points N/A #170633
1- First check if you can remotely access the computer to the workstation through another computer.
2- If you can access the computer successfully so the problem is on your PC or laptop,
So to solve this problem:
3- Check the firewall, it might block the remote access connection.
4- Or there is a proxy that blocks the connection to the workstation.
