Remote Desktop connection to Windows.
Has your work ever come to a halt just because you do not have a file on your Laptop? But you have it saved on the Desktop at home? Now here is a way you would complete your work without any delays.
First: Make sure that the following settings are in place for both the Windows Desktop you wish to connect.
->Right click on the ‘This PC’ or ‘My Computer’ Icon on your
Desktop->Click on Properties->Go to the Remote Settings tab->Tick the box to allow remote assistance.
Second: It is important for you to know the Computer names of both the Computers.
Go to Search and search for Remote Connections. This Window will pop up-
In the given box type in the name of the other PC you wish to connect. Click Connect.
Then put in your Username and Password-> Click OK.
Your PC is now connected.
