I have a problem with Remote Desktop Lite, concerning the resolution of this application, which is running on my Galaxy Note 10.1, the app is squeezing itself in the middle of the screen and some parts are not displayed well, I have been manually resizing this application every time I launch it, How do I get a full screen display? What could be the problem?
The problem you are facing is the most common problem related to all remote desktop application, be it on windows platform or android or MAC.
In fact, if you use a host machine from PC/laptop using remote desktop mechanism, you also find this kind of issue. However there is a feature called auto resolution change – which is linked to device rotation.
So why don’t you hold your device in landscape mode and give it a go and check whether your problem gets resolved or not.
The Samsung Galaxy Note 10.1 is a discontinued 3G tablet operating on 2G and 3G network bands using GSM and HSPA. It was announced to the public and released on August 2012 measuring 262 x 180 x 8.9 millimeters and weighing 600 grams. It uses mini-SIM card and includes a stylus. It has PLS capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution.
It ships with Android 4.0.3 Ice Cream Sandwich upgradable to Android 4.4.2 KitKat with TouchWiz UI powered by 32 nm Exynos 4412 Quad chipset, 1.4 GHz Quad-Core Cortex-A9 processor, and Mali-400MP4 GPU. It supports microSDXC. It runs on 2 GB RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB.
The primary camera supports 5 megapixels with AF featuring LED flash. It supports 720p video recording at 30 fps. The secondary camera supports 1.9 megapixels. It has 3.5-millimeter jack; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS and GLONASS support; infrared; and proprietary USB connection.
It doesn’t have FM radio. It has built-in accelerometer, gyro, and compass sensors. It runs on non-removable Li-Ion 7000 mAh battery with standby time up to 1500 hours and talk time up to 33 hours 20 minutes. It is available in black and white/silver colors. If you have a problem with the app, try downloading the latest.
Download Remote RDP Lite. The latest version at the moment is Remote RDP Lite 4.5.0 updated on March 14, 2020. It requires Android 4.0 Ice Cream Sandwich and up. This is rated 3+.
1....
