The remote server returned an error: (500), Internal Server Error
Hi Experts,
I have received an awful error message regarding Live Writer of my Windows.
The error message indicates that
The remote server returned an error: (500), Internal Server Error.
I cannot understand the error message. Is there anyone who has an idea regarding that error message?
Please help.
Thanks in advance.
Best Answer by Toni Linscomb
Answered By 10 points N/A #144509
Hello Jiim,
To resolve that issue, you will need to try debugging the server method on search.aspx. If you cannot be able to do that, you will need to just set custom Errors element in web.config to Off. That will make the server to return an error's full description.
You can also try recompiling your whole application, and ensure that all the required dlls are there in bin folder when you recompile it.
Carl
Answered By 5 points N/A #144510
The 500 Internal server error is a server side error nothing to do with clients computer or internet connection and it’s a failure of the server. Saying that you can still try with some thing.
Reload the web page. You can do that by clicking the refresh button on the web page. Try this because server may be down temporarily and refreshing will often is successful.
Come back later. They might be fixing the issue so you can come back and try later.
If above doesn’t work then contact the customer support.
