Remotely Access computer from mobile.
You will need to register with SoonR and then download and install that will run on the background services. While installing, you can identify which folder or drive you wish to use for accessing remotely. The default folder is the My Document for remote access.
And then, go to your browser or open SoonR on your mobile through GPRS. You will be directed to the log in screen wherein you will be asked to enter your username and password that you just created.
After logging in, you will see the Desktop and Organizer option and the Google Desktop Search box. When you click on the Desktop link, you will have access to My Documents folder or any folder that is available for accessing remotely.
Use your Outlook or Mac Email Account to receive or send emails and share your documents with friends. You can have up to 100 MB of file to be stored for accessing it any time. You can gather all your files and put it on one folder so you can access it anywhere even if your computer is turned off.
If you provide computer support, you can log into your customer's computers from anywhere in the world and fix their problems remotely!
Your customers don't have to install software, purchase licenses, or learn complex procedures.
