Remove Administrator Password In Windows 7 Using Easy Setps
Hi. I am using Windows 7, and I want to learn how to remove the password of the administrator. How to remove administrator password in Windows 7? Please reply ASAP.
Hi. To learn how to remove administrator password in Windows 7, it can be reset via the administrator in safe mode by rebooting the PC. Then, press F8 key till the Windows Advanced menu appears. Then, the safe mode which appears on the screen needs to be clicked on and then press the enter key. Then, the admin account should be logged in using the credentials. By clicking on start, then select the control panel, and then select the user accounts.
The password can then be reset. Alternatively, reset disk can be used to reset the password by selecting the option of resetting the password. Then, click on the password reset option after which the reset password window will appear. Then, click on next and insert the password key disk. Select it from the menu and then click on next. Then, enter the password and then finish the operation.
Hope we helped.
