To Remove And Install The Ink For Epson Workforce 610
Hi. I am not very familiar with the computer-related hardware and software. I want to know the steps to remove and install the ink for Epson Workforce 610. Please reply ASAP. Thanks in advance.
Hi. The steps for removing and installing the ink for Epson Workforce 610 require you first to ensure that the CD is not inserted. Then, turn the printer on. If the cartridge is being removed before a message is seen on the LCD screen, click on setup, OK, maintenance, ink cartridge replacement and then click on OK again.
Then, the unit of the scanner needs to be lifted up. Following this, the blue tab needs to be pushed so that the ink cartridge which is to be replaced can be unlocked. Then, remove the cartridge by lifting it from its bottom. If the cartridge is being replaced, it should be shaken well before it is started to be unwrapped. Then, insert the cartridge into its holder after which it needs to be pressed to the bottom so that it lies into place. Then, after all, the cartridges are replaced, the scanner unit should be closed.
Hope we helped.
Notifications
