I am using HP ScanJet 7650 Flatted Scanner also I am using Mac Operating system but I am receiving below error when I try to scan a slide or Negative. All error detail is given below so that you can understand original problem easily. Please tell me its solution urgent.
Remove any originals from the scanner glass. Ensure that your TMA is connected securely and positioned correctly. See your user’s manual or electronic help for more information about setting up you TMA.
        OK
Remove any originals from the scanner glass Error
Hi there Shaheen.
The problem you presented could be caused by anything related to using the TMA from connection to usage. To help you troubleshoot the problem, here are some links from HP that might contain the information you need.
This is the Guided Troubleshooting page. This is where all the links related to the TMA are indexed:Download Link1
Here's the guide for connecting the TMA (Transparent Materials Adapter) to your flatbed scanner: Download Link2
Make sure you follow the correct procedure in connecting the TMA because I think the problem being reported by your PC is related to how you connected the TMA to your flatbed scanner.
The next 2 links are usage instructions for the TMA. Make sure you follow the tips and procedures accurately:
Download Link3
Download Link4
