Remove Personal Information from Active X control
There are some files like active X controls, XML expansion pack information, or web components. Personal information can easily include in them. But unfortunately they cannot be removed by the Document Inspector.
So I need a solution removing these data. Please anyone help me.
I will be highly thankful.
Answered By 0 points N/A #151417
Hello and welcome to the site.
If you are an administrator, I suggest you to use the Disk Cleanup Tool Under Windows.
Click Start > Programs > Accessories > System Tools > Disk Cleanup
Another way to launch the Disk Cleanup Tool is by running “cleanmgr”
Click Start -> Run and then type “cleanmgr”
A Window will be displayed and you will be prompt to choose the drive you would like to clean up.
After clicking OK, this tool will scan your chosen drive, then delete temporary files, clear internet caches and so on which will also delete your personal information.
