I recently purchased a dell laptop and I am very satisfied with it. I just have one issue, when I got my laptop from the retailer, It already had an unusual amount of software on it. I want to know what software are safe to install and keep the laptop running smoothly.
Remove producer pre-installed software on laptop
Whenever buying PC, many software come installed previously. You can easily uninstall them from your system.
1. From Start menu, go to Control Panel >> Programs >> Programs and Features.
2. Right-click on the unwanted apps and select “Uninstall” or “Uninstall/Change”.
You can also use any third-party uninstallation software like Revo Uninstaller, Wise Program Uninstaller etc. They are quite good uninstallers that helps removing every single file left by the uninstalled software.
