Remove rms protection in word 2010
Hello,Â
I am using MS Word 2010 and trying to remove rms protection in word 2010. Please suggest me, how ca we remove rms protection in word 2010. Please send me the appropriate solution.
Thanks!
Best regards.
Hello,Â
Thanks!
Best regards.
Hello Nevil,
If you want to remove RMS protection from all the protected documents in one time then you can use the ad RMSÂ decommissioning process. This process will remove protection from all the protected documents.
Click here to know more on RMSÂ decommissioning process:
If you want to remove the RMS from the some documents then you can use script based action with the Bulk protection tool.
Click here for the script based method:
I hope this will solve your problem.
