Remove save video as any format file.
Hello experts,
Remove save video as any format file. I would like to know what is the best way to remove save videos in my laptop with a computer operating system of windows 7 starter? I just want to know the process of the deletion for I was having an error like unable to delete file. I hope you can help me. Thank you.
Best Answer by CORDOBA Ferrer
Answered By 5 points N/A #184621
What kind of files are you trying to delete, please state the file extensions, the location from where you are deleting them please be more specific on your question or better yet attach a screenshot of this said file. But for now you should try out this software http://www.piriform.com/ccleaner/download , it removes most of the useless or unwanted files in your computer. Just install and run it once and see if those files will be removed.
Answered By 0 points N/A #184622
Hello Thomas,
CLick the file and then right click delete. or Click the file then Press the Delete keys. And delete it also on your Recycle Bin. Hope this helped you!
