I want to remove time restrictions from some of my PDF books. Is there any way to remove time restriction from pdf books? If there is a way to solve this problem then please provide the solution.
Remove time restriction from PDF books
Hello Castane,
Good day.
PDF has a special feature to secure data that it contains so that the document owner or the author can protect the file or the data from unauthorized access., thus sometimes the security or being protected seem hard for the owner of the file to open.
In this case you cannot open the PDF file since it has time restriction. But don’t worry because we have a software to use for this to unlock the time restriction and you can open the file.
PDF Unlocker is a software used to unlock any kind of restrictions on your file, can be password restricted or time restricted.
Once the PDf file has been unlocked you can do printing, editing or even copying or extracting the file.
One good feature of this software is that it runs into all kinds of Windows versions.
All you have to do is to download the software from the main window of the program.
(Please see at the upper part of the page "Download PDF Unlocker" colored light green with arrow down logo) similar to the screenshot below;
Just have to click “Download” and then click the “Save File” and then check it from your
Download file, open it and click the “Run” button. Install the software.
And there you have it!. You now have installed and ready to use the PDF unlocker.
I hope this would really help you.
Thanks and Have a great day!.
