Removing cookies from Android mobile
I have an Android mobile on which I frequently use internet. I wish to know how can I remove cookies and unwanted files no longer needed.
Lauren it would be a great help If you elaborate the process of removing cookies.
you can clear it easily
go to your mobile phone settings > application > select manage applications > click on browser and clear
now your problem is gone.
alternatively there are some android applications in android market which you can download. from using these applications also you can clear your history and all the cookies very easily
im using history eraser application from history eraser i can clean almost everything. there are so many other application too
here is the link for it
thanks
Did you erase ? If you have any problem with above methods just let me know. I will help you again from another method
Cheers
I apologize Lauren, wasn't able to see the complete solution,was able to view just the first line, guess some problem with page loading.
Thanks for the solution, think its great 🙂
