Removing the file command brings the permanent removal option
Each time I try to delete something the option is always permanent delete option. There are times when I may mistakenly delete more items and than restore them using recycle options.
But permanent delete is causing problem. Should someone know of the problem kindly let me know of the solution.
Jobert Bridges
