Removing a ghost out of proc without rebooting
Without rebooting the computer, can I remove a ghost out of proc which started running in my computer after I deleted a guest directory without shutting down?
It is 100% possible.You shouldn't only to delete a guest directory to check update of your computer.At first you will find out whether the name of the ghost will be shown.Then you can turn your computer mouse and uninstall the ghost.And it will abolish the ghost from your system forever.For this reason you will not need to shut down your computer rather you have to only uninstall the program only.It will work like a magic.You will not see the ghost again.This is 100% percent guaranteed.You don't need rebooting your computer for this work.
Please follow below instructions to remove the unwanted ghost devise from your programs.
Go to command Prompt>> type “set devmgr_show_nonpresent_devices=1” and enter>>type “start devmgmt.msc” and enter >>In the Device Manager in control panel troubleshoot for devices & drivers >> Close the window and exit from the command prompt. No need of rebooting your computer.
I am glad to be able to help you in solving your issue. Please let me know if you are successful.
