Removing HP Tools From A HP Stream 11
I bought a HP Stream 11 for my daughter knowing it was limited in performance. But when I check the CPU it is being over run by something called HP Tools. Will my computer crash if I shut down the service? Can I completely remove it from my computer to speed up the internet connection?
