Removing mp3 toolbar from Explorer
Somehow I got an mp3tube toolbar in my explorer . Now I need to remove it . But i can't remove it. Can anyone help me with that.
Hi there,
Please follow this procedure to get rid of the mp3 toolbar in your explorer:
Start your “Internet Explorer”, and then click on the “Tools” icon and choose “Manage Add-ons→Enable or Disable Add-Ons”, and in the drop-down box marked “Show”, and choose Add-Ons Currently Loaded in Internet Explorer, then click the Name column heading.
You should see a list of add-ons, sorted by name. One by one, select any toolbars that you don’t want, and any “helpers” that come along for the ride, and click Disable. Just disable the toolbars do not delete.
And when you’re done slashing the unwanted critters, click “OK “ twice, “X” out of Internet Explorer, and then restart Internet Explorer. The mp3 toolbar’s gone.
Hope this help you
Hello Dear,
It is very easy to remove a toolbar from Internet Explorer. As you said, you want to remove the MP3tube toolbar from your browser. To do this, open your Internet Explorer. When the Internet Explorer window appears, choose the view from the menu bar, and it will open a list containing many options. You should choose “toolbars” from this list.
Then, one more list will appear. This list contains all the toolbars that you have installed. Just remove the tick from the MP3tube toolbar. It will remove the toolbar, but now you have to go to Add/Remove programs to remove the toolbar permanently from your system. This action will only remove it from the Explorer page, not from your computer.
I hope this helps you understand. Thanks.
