Jimmy Perez
30 points
Posted on - 04/07/2012
Hi Guys,
A website took over my homepage and search engine. I have no idea how it came. I tried in browser’s setting but I failed.
How can I remove this site completely from my computer?
Thanks in advance
Removing a site completely from computer?
If your using Google Chrome just click the settings for chrome and try to find themes that suits you. Or try to go to the settings wrench tool>> click the history>>  and check all the browsing data..>>  and from that a message box will and you can choose from the choices which of  the following you will obliterate then press the clear browsing data.. Chrome has the easiest way to surf the net and change the settings.
For internet Explorer:
Click tools and then internet history. Click delete browsing data. If you didn't want to delete favorite, then click to place a check mark in the boxes next to the information you to delete. Then click delete button.
For Firefox :
Select everything from the menu which is top of the window. Click to mark in the boxes what you want to delete. Then simply click delete button.
For Chrome :
Click to clear browsing data and place the mark and then you can clear all of the browsing history.
Simply delete all your internet history.
