Removing Twinui Error
In recent weeks, the default application was used for gap or video files, and I have an open file for which I bought an incorrect calculation language, Windows does not recognize the file and displays the path of access to the file. Then he suggests that I check my information and check again. This can be the case by clicking on the nail. After reviewing the default applications, I see that a TWINUI has been set as the default. After catching up, I still see TWINUI as a partner in the choice of nursing. Is it possible to remove all mentions of TWINUI, whatever their situation, in Windows 10 so that it does not happen anymore?
