Removing USB from being write protected
I'm wondering how this happen, I'm trying to format my USB but it is write protected, How can I remove it ?
You want to format your USB device. But you did not mention whether the USB device is currently running well or not. If yes, your USB device is corrupted with virus. You may not be able to format your USB device in this position. To format your USB device you may go through the followings:
1. If there is an antivirus running with your PC – scan the USB device first. Make sure the antivirus has scanned your device properly. If your running antivirus is unable to scan it, then another new version of antivirus may be required.
2. After scanning the device you can proceed to the command Format.
3. You can also take the necessary backup of your important data from the device before formatting.
I hope you understand it.
Thanks
Hello Robert,
You may try the following instruction while your USB is inserted to your computer.
1. Reboot your computer.
2. Press F8 continuously until advance boot option screen appear.
3. Select Safe Mode with Command Prompt.
4. Type C:windowssystem32>and your USB drive letter and press enter.
(example: Â C:windowssystem32>E:) Letter E is your sample usb drive letter.
5. E:format E: press enter.
6. Press Y then enter.
7. Your USB write protection has removed.
Hope this will help.
