Removing Vzspeedoptimizer100 Exe File
I have noticed a file vzspeedoptimizer100 exe in my system. I think this file is creating some sort of nuisance in my system. I wish to remove this file but I am not able to do so. If anyone knows steps for the same? Please help!
Answered By 10 points N/A #320387
Follow these steps to get rid of your file
Run the Asmwsoft Pc Optimizer application. Then select “Process Manager” in the main window. Wait a few seconds. After the process list is displayed, scroll to find the vzspeedoptimizer100.exe file you want to delete or shut down. Click the vzspeedoptimizer100.exe process file, and then right-click. Then select “Add to Blocking List” from the list. This prevents the execution of this process.
