Hello there.
I’m looking for a software that can rename a lot of files by batch.
Where can I download the Rename Master software?
How do I install and will it be compatible with my Windows 7 64 bit desktop?
Does it have an easy to use UI?
Is Rename Master compatible with Windows 7?
Yes, Rename Master is compatible with Windows 7.
You don't really need to install it to use it, but there's an optional installer if you want to.
For the UI, it is easy to use.
The controls are within reach, the command names are quite straightforward, and the website has thorough documentation.
You can download Rename Master here.
Rename Master is a freeware program designed to do complex mass renaming operations with a simple mouse click.
The program offers an incredible control over how and what files to rename.
This is a great program if you have a huge number of files stored on your computer and you are wondering on how you would be able to rename this pile up of files the easiest way without accessing the files individually. The program uses multiple-level instructions that’s why it is easy for you to change only a portion of the filename and you can do it in only one operation.
The application uses a default script that covers majority of the basic operations and if you want to create one yourself, you are also allowed to do it in the program.
The program can be used as smoothly and as quickly even if you are working on a large volume of files. The program also features a preview function where you can preview the output when doing numerous changes to a file even if the program haven’t done the task yet. This freeware works on Windows XP, Windows Vista, Windows 7, and Windows 8 and can be download.
Also watch “How to Rename many files with Rename Master – tutorial by TechyV”.
[video:http://youtu.be/87qfxDDWYiE]
