Rename Master a Renamer Program
Want to change name
George_Brett to George Brett
Removing the _ from the name
Thank you for your time My email is below
Want to change name
You are probably asking how to rename or change your username in TechyV. To do that, log in to your account first then go to or click your username.
This should open your TechyV account. Next, select “PROFILE” then “EDIT”. Under “Name (required)”, change your name. From “George_Brett”, just delete the underscore “_” to rename it to “George Brett”. When you are done, click “Save Changes” at the bottom of the page to save the changes you’ve made to your account.
And that’s it. Your username should now display “George Brett” instead of “George_Brett”. In case your username didn’t change, make sure you saved the changes in the previous step. Log out your account then log in back. This should fix the problem.
Notifications
