Hello experts,
Rendering problem with sony vegas 7 3gp. We created a dubbing movie scene directed by me in a 3gp file format. I want to use sony vegas 7 to edit the 3gp file format. Suddenly when trying to import the file there is an error occurred saying file unsupported. Help me to resolve this issue. Thank you.
Hello Martha,
Well, you will need to check Sony Vegas and confirm which files are supported, because if the 3gp file format cannot work with it then you will not be able to edit the file as you want. Once you know the supported formats, you can convert the 3 gp file format into one of those formats and the edit it.
Nicke
What type of 3gp file you are using to convert may be its stream bit rate is not same or there is some common error that is causing this problem. You need a 3gp file that has the exact format that is supported by the Sony Vegas 7 and you will be able to convert the file.
Smith Thompson
