Hello Techyv Guys, I need a help on fixing or to repair a bug in Word document. I am using Word 2010 and is getting a message while opening a docx file, the message is saying that "The file cannot be opened because there are problems with the contents. The XML data is invalid according to the schema." Please give a solution.
Repair a bug in Word document
Xml Error is brought about when the computer loads with too much data, or when particular system files turn out to be missing or broken. It is a serious symbol of unsteady system that is usually affected by unsuitable care of the computer. Symptoms of Xml error can include lock-ups of Systems, slow performance of PC, freezing of system, change of color of screen, start-up or shut down problems and errors in installation. Use a Free Download Repair Tool(SmartPCFixer) to scan, diagnose and repair the computer, it is designed to diagnose and repair errors that bring about breakdown of the computer. Or you can Un-install then
Re-install Microsoft Office 2010.
