Repair Windows Media Player with Fix WMP Utility
Hi Troubleshooters,
I have a problem with Windows Media Player in the computer. When I try to open WMP, I was stuck up with an error message. This is very annoying to me while I am working with other applications. I know there is some problem in WMP, I am not sure whether I can run this utility to fix the problem or it will create more problems. Please help to solve this error. Thank you.
Fix WMP Utility v 1.0
This portable utility re-registers all the concerned Windows Media dll files required for the smooth functioning of Windows Media Player. If you are facing any issues or getting any error message while running Windows Media Player, run this utility.
