Repeatedly showing SSL certificate Error
After many days I just installed windows XP in my computer.
It was a hasty installation.
When I installed my required software there were no problem at all.
As I started to browse the pages that starts with "https" , I can not go through that particular page but it showing SSL Certificate Error.
How can I fix the problem now.
Answered By 0 points N/A #115193
Hello Leona Medley,
Before connecting the Internet your first task is to be ensured that whether the time, date and year of your computer is correct or not. If the time, date and year is not correct then correct those and then refresh your computer and after refreshing properly you can be connected with the Internet. I think you will have a happy browsing.
Actually SSL certificate is nothing for you because it is used at the time of transferring sensitive data over the Internet but you are just an Internet user, so don’t worry about it and if you be connected with the Internet by following the instruction above then I think you will have a happy browsing.
Thanks for your patience
