I started using Exchange 2010 and Outlook 2010 some time back. I have now created a new logo in Exchange that I would like to place instead of the previous one on the header of Outlook. Can this be done? Can an expert guide me on how to do this,.
Replace old logo with new one on Outlook header
In the outlook under the File menu, select Page Setup->Define Print Styles. In the Define print style dialog box select the print style you want to use. Now click on the Edit button. Under the page setup dialog select Header/footer tab and add the required information. However, I do not think you can add a picture to that. All you can do is to add user name, page number, date/time etc.
