I have the iPhone 3 and an iPad. I need to get a newer iPhone as well as the iPad. I am not looking at too expensive gadgets. What do you recommend? It doesn’t have to be the latest just a good one is enough. Something that I won’t want to replace soon. And also how can I switch brands without losing iTunes music and apps?
Replacing old phone brands without losing data
There are five apps that can help you transfer your iTunes and apps from your iPhone 3 and first gen iPad to another brand.
1. Google Play Music
Download music manager on your PC and then import your iTunes folder straight to your Google Play Music. Then upload the iTunes music to the cloud. Then after you download the Google Play Music Android app, you can access you music too.
2. iSyncr
You can download directly with the iTunes program if you have the app on your phone. It's one of the simplest and easiest ways to transfer your iTunes to another phone or tablet brand.
3. Easy Phone Tunes
This is also very easy to use but before you can directly transfer your iTunes to another phone or tablet brand, you need to download a PC application first. You need this application to import first your iTunes library. After that, you can sync the files to your new phone or tablet using an Android App.
4. iTunes to Android Wireless
This app also transfers your iTunes easily but there are two versions. One is free and limits what you can transfer. The PRO version is unlimited.
5. TuneSync
You need a free program from the TuneSync website first. After that, you can transfer your files without a cable connection if there is wi-fi connectivity.
Lastly, if you are looking for a new phone that is cheaper than your iPhone products but has excellent performance, you are in luck because Motorola has just launched its new smartphone, Moto G. Optimum performance is guaranteed with its all day battery, 1.2GHz quad-core Qualcomm Snapdragon processor and has the latest Google Android operating system.
