Hi all,
I'm working with Outlook 2007 on a Windows 2007 OS via a Gmail account (pop3). I get the error message while I send and receive reported error (0x8007000E): Out of memory or system resources.
Close some windows or programs and try again.I am safe on other windows or programs to open. Don't know how to deal with it.
Please help.
Reported Error (0x8007000E): Out of memory or system resources
You encounter an out of memory error maybe because your computer only has a small amount of RAM installed. If you can add more RAM on your system, it will not only fix the problem with Microsoft Outlook 2007 but it will also make your applications load faster and have smoother operation.
But you can also remedy this without adding any additional RAM.You just need to increase the allocated page file of Windows 7.
Usually, making the swap file 3 times the size of your installed physical RAM is more than enough. If ever you encounter it again in the future, try closing some applications that are currently running to reduce the memory load of the computer.
Not enough memory on Outlook 2007 does not mean there is no sufficient memory in your computer or drives. It means that memory available on the Outlook 2007 to hold data or information has been filled up or application has run out of memory. In another word there is low virtual memory.
So you have to increase virtual memory,try to uninstall some other programs that are less important. But first try to uninstall the application,save to another location and delete the program folder. Then re-boot and re-install the application again.
If it does not work then it may be happen due to damage of MAPI32.dll file.You have to fix this file using MAPI Repair Tool. You may find the file Fixmapi.exe that have to fix on the folder C:WinntSystem32 or on the folder C:WindowsSystem32.
Then another case, your email profile may be damaged. Please create new profile and restart Microsoft Outlook 2007. Another case may be occur,do not mind please.
There may a corrupted email message. You may check this by moving messages. The damaged message will not move. You have to delete it. If this is a important email and you do not want to delete it,you have to repair Outlook PST.
To repair Outlook PST you have to buy software from market.. But before trying the methods above remember that the problem you faced,may be also due to Microsoft Outlook 2007 used much memory.
So close all program including Microsoft Outlook 2007 and reopen Microsoft Outlook 2007. It may solve your problem.
