Request the terminal services client of juniper networks fox for safari
Hi experts !
Could anyone help me on how to make the juniper networks fox for safari work on a Mac OSx Version 10.5 ?
I would appreciate if you describe the steps to be followed for both the installation process plus the configuration.
Many thanks.
Answered By 0 points N/A #195419
Hi!
Your question is very important to all. I have just researched and got the perfect solutions.
For installing  juniper network on MAC you have to install the latest edition of java 10.7.
After installing restart the operating system. Then you should be present at Applications
Launch the Utilities folder and select the “Java preferences” app.
 Now enable the java applet plug in and  web start applications located at the top of the window.
I hope this will help you.
Thanks
Nowell
