The Requested URL could not be retrieved
Hi experts,
I found this error message. I don’t have any idea. Please help me to solve it.
Thanks a lot.
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL.: http://co120w.col12Omail.live.com/mail/EditMessa
The following error was encountered:
• ICAP protocol error.
The system returned:
[No Error]
This means that: Some aspect of the ICAP communication failed. Possible problems:
• ICAP server Is not reachable.
• Illegal response from ICAP server.
Generated wed, 06 May 2009 16:01:59 G by localhost (squid/3.0.STABLE1)
Best Answer by Argen Manso
Answered By 15 points N/A #153513
If you are using windows 7 operating system I can give you a tip on how to access the website.
Go to your control panel
Click Network and internet
Click internet options
Under the security tab
Go to Trusted sites
click the green check icon
Below that click the "Sites" button
and add the website name in to the "add this website to the zone"
I hope this will help you
Answered By 0 points N/A #153514
Hi Asten,
This problem may appear for your http client, server configurations. At also causes for network configuration settings.
Try this solution. Delete your history, clear your cache and clear all temporary files. Now, see.
