Require instructions for Creating Fillable Forms in Word 2010.
Hey everyone,
I have upgraded my Microsoft Office from 2007 to 2010. Now, I’m unable to create the Fillable Forms in MS Word 2010. Someone, provide me the instructions for Creating Fillable Forms in Word 2010.
Answered By 0 points N/A #127613
The Process to add the Fillable Forms in Microsoft Word 2010 is pretty much similar to creating those in MS Word 2007. The only difference that a user will find is the method by which you can enable the Developer’s tab in the Toolbar. By Default, the Developer’s Tab is not visible.
Follow the steps to enable the Developer’s options.
1) Click on the File Menu.
2) Select “Word Options” from the list.
3) A Dialog Box will open up.
4) Click on Customize Ribbons, and put a tick beside “Developer.”
That’s it; you will now find the Developer’s Option in the Toolbar. Now, place the pointer where you want to add the fillable unit.Click on the “Design Mode” option in the Developer Tab. And Select “Aa” or “Aa”.
After that, you can insert the Fillable Form.
