Required Adobe flash player for home tablet like Ubislate
I have recently purchased ubislate Tablet for my home purpose but due to some certain reasons it flashed and few files get damaged due to that I am unable to see any flash supported files please provide some solution to install again adobe flash player for home tablet ?
Best Answer by Garrison Roger
Answered By 0 points N/A #198137
Ubislate Tablet, Originally made by world famous Indian it student, Which initially called Akash, Akash ubislate tablet made for student and study purchase, Its a low cost device,
Hence you will encounter some issue, Thou tablet is good for study and entertainment purpose,
Check the link from where you can download the Adobe Flash player.
Thanks
Answered By 0 points N/A #198138
Hello Skylabreonna,
I have found a solution to your problem.
You can now download and install the Adobe Flash Player onto your tablet.
Hope this would work for you:
Adobe Flash Player
If you have some other problems you can post here.
