“A required CD/DVD drive device driver is missing” – Hyper-V
Hi experts
When I try to install the Windows 2008 R2 like a VM in HyperV, I got the following error message appears:
“(Load driver) A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now.
Note: If the Windows installation media is in the CD/DVD drive, you can safely remove it for this step.”
When I got this error message, I was quite astonished because I had done this before by the same way.
However, quickly I realized the reason behind this error message: it was a damaged ISO file.
Then i solved this problem by this way: again have to download the ISO file from a reliable source, or try to get yourself a Windows 2008 DVD, and accumulate it to the VM.
Please just tell me how this ISO file got corrupted? Please help me to find out this. Thanks.
Error: “(Load driver) A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now.
Load Driver
Note If the Windows installation media is in the CD/DVD drive, you can safely remove it for this step.
