ria tolart
10 points
Posted on - 01/21/2013
Hi experts,
I have heard a lot about GPS Diagnostic 105 utility. I need proper documentation of its usage that how i can use it and where i can find its download. I hope i will get positive response.
Required direct download link + Information of GPS Diagnostic 105 Utility
Hi Ria tolart,
You are looking for GPS diagnostics v1.05 utility. This is user friendly Application.
Basic functions of this software are:
1. Detect when Microsoft Bluetooth is installed but turned off.
2. Configure the GPS Intermediate Driver to correct COM port and baud rate settings.
3. Suggest ideal COM port and baud rate settings to use.
4. Recommend one device as "most reliable" when multiple devices are detected.
You can directly download from this mentioned URL.
I wish this solution may be fruitful. Thanks!
Best,
Fenster Maxine
