Required posts for opening a firewall between two forests
Hello experts
I need to know one thing. What ports are required for opening a firewall between two forests for user communication? Please help.
Thanks a lot.
Hello experts
Thanks a lot.
Please find below, the steps to be followed to open a port manually:
Follow the above mentioned steps in sequence to open new ports manually.
Here is a list of ports which are used in case you are using Windows NT:
Client Port(s) |
Server Port |
Service |
137/UDP |
137/UDP |
NetBIOS Name |
138/UDP |
138/UDP |
NetBIOSNetlogon and Browsing |
1024-65535/TCP |
139/TCP |
NetBIOS Session |
1024-65535/TCP |
42/TCP |
WINS Replication |
In case of Windows 2000 and 2003 server:
Client Port(s) | Server Port | Service |
1024-65535/TCP | 135/TCP | RPC |
1024-65535/TCP | 1024-65535/TCP | LSA RPC Services (*) |
1024-65535/TCP/UDP | 389/TCP/UDP | LDAP |
1024-65535/TCP | 636/TCP | LDAP SSL |
1024-65535/TCP | 3268/TCP | LDAP GC |
1024-65535/TCP | 3269/TCP | LDAP GC SSL |
53,1024-65535/TCP/UDP | 53/TCP/UDP | DNS |
1024-65535/TCP/UDP | 88/TCP/UDP | Kerberos |
1024-65535/TCP | 445/TCP | SMB |
Hope that this data helps you.
Notifications
