Lamb Cutlip
Posted on - 11/02/2017
I have upgraded the exchange server 2007 to 2010 as the Microsoft has ended its support to exchange server 2007 and will not be providing assistance. I want some tips related to exchange 2010 administration so that I can manage it properly.
Required Tips For Exchange 2010 Administration Server
Due to the Microsoft ending its support to exchange server 2007, it is important to upgrade your system to exchange server 2010. The fact is, you will not get any assistance from Microsoft and any newer updates which in turn will affect your data and system as per the security reasons.
It helps in maintaining your data and fixes issues not being dealt in exchange 2003 and exchange 2007. Make sure that you have removed exchange 2007 or any older version if you want to install exchange 2010. It helps in maintaining server more efficiently by providing you with all the services briefly managed and explained.
It encounters less troubleshooting problems and relieves you from the problems that were not treated in the lower versions. It is a more briefed out version in case of any amendments and changes.
