Requirements to use Windows Phone Device Manager
Dear All,
I am using Windows 7 on my PC went to install windows phone PC manager for my Windows 7. Can anyone help me to find it? What are the requirements to use it?
Dear All,
Good day Allison,
You didn`t give me enough information on what version of the windows mobile OS you're using. If you're using the latest windows 7.5, 7.8 on your phone, then it`s easy.
You can sync your videos, pictures, load ring tones. You can also play your audio and video files on this app.
The next time gives more info on the phone to give you a better answer.
I hope this will be of some help to you.
Hi Allison,
I would suggest you the following link to get your windows phone device manager for your PC.
However it provides support only to select window 7 phone devices likes of HTC, Samsung, Dell and LG about which you can have detailed overview in the link below.
http://www.soft-zilla.com/2011/04/windows-phone-7-device-manager.html
You will also find a video in the link to help you get used to the software.
Hope this helps.
Thanks
Baker
