Rescue PRO file recovery for Mac
Asked By 85 points N/A Posted on -
Hi Guys,
I am using Mac OS X in my system and need to recover the deleted images from my Memory Stick. Will Rescue PRO file recovery for Mac will help me recover deleted or formatted images from my  Memory Stick. Please advice, if it won't work, suggest me any software that can help me to recover data from Memory Stick.
Thanks,
Luke N Marks
Best Answer by Waters Magner
Answered By 0 points N/A #170336
Yes, Rescue Pro File recovery for Mac is a good software to recover stills and video images. It is an easy to use software which helps in recovery from your memory stick or camcorder.
If you looking for other software for Mac, You can look for Yodot, Card Rescue, Applexsoft.
Answered By 5 points N/A #170337
It will work definitely but I would like to suggest one awesome software that will solve all your problems. It is the Stellar Phoenix photo recovery software and this is going to scan all the drives and memory units both internal and external in few seconds. It will recover the photo that you have suggested to recover. However, it can recover for you files as well as videos though the name does not suggest that.
It is rated high and has been used successfully by many. If you suffer from overwrite problem then this is going to solve your problem. Any device, It will work fine on Mac OS. You can resume your previous search if there is a power failure. You can first opt for free version. There are some limitations but that is going to solve your problem anyway.
Stellar-Phoenix-Photo-Recovery-image
Waters Magner
