Dear Friends,
I am using Kingston Pen Drive and I need to recover accidently deleted or formatted files from my pen drive be rescued and restored. Is there any Rescue Software of Kingston Pen Drive, that will help me to achieve the task or suggest me any better software.
Thanks,
Miguel M Burch
Hello Miguel M Burch,
Kingston have their own recovery tool called MediaRECOVER. It's an easy to use tool that can help you recover over 250 file types. You can download the latest version from Kingston's official website. There is also a Mac version which is neat.
Good luck!
Here I recommend Wondershare Data Recovery, or Wondershare Data Recovery for Mac for you. No matter your Kingston flash drive data are lost due to formatting, system problem or accidental deletion, they can be easily retrieved with this program. The program is compatible with both Windows computer and Mac.
Although recovering data is a painstaking process but don’t worry have many ways to recover your data easily. To get another technique I have mentioned a Techyv’s page where you will get that new trick.
How to recover deleted data
To answer your question  I have been following instructions as listed below.
The problem of using Kingston Pen Drive  as shown in the image and want to recover deleted or formatted files accidently, you have to install software data recovery. ICare data Recovery software is best for the solution to your problem. It will recover your formatted files.
