Reset Passwords In Startalk Flash.
I am using startalk flash and I need to change the passwords for Operator and system manager. I need help doing it. Any help would be appreciated.
Resetting the system manager password and the Operator password is very easy. System Manager: – Go to the feature 985. Press 9 after the startalk DN is displayed. Now type RESETSMPSWD i.e. 73738767793. Now it will ask you if you want to reset your password. Press ‘yes’ and the password will be changed to default (120000) Operator: –
Again, go to feature 985. Dial 7 after the startalk DN is displayed. Now press RESETOPERPSWD i.e. 7373867377793.
Press ‘yes’ when asked to reset password and the password will be changed back to default OPERATOR (67372867)
