Cohen Allen
10 points
Posted on - 04/18/2017
Hi, I’m using HP Office Jet 5610 all in one printer and using windows 7 operating system. I’m getting an error 0xd620111 (sometimes different) Rest power. Please give a solution, thanks in advance.
Resetting Power Error In HP Office Jet 5610 All In One.
Hi, this problem occurs when printer didn’t get enough power supply. So first check your power cable connected directly to the walls instead of sockets also check the connection between PC and printer make sure USB connected to the major USB slot. If above procedure not worked, hard reset and repeat above steps. Procedure to reset is, turn on the printer and disconnect power cable from the rear side.
Unplug power cable from wall and PC respectively (possible remove left cartridge) Wait for 2 to 3 minutes then hold the power button for at least 30 seconds (make sure power cables are unplugged). Now reconnect all power card as mentioned above then the printer will automatically turn on if not press power button.
